Settings that will give the best Mid bass
  • 6
JeffM
Im trying to tweak some settings on my Pioneer 780 that will give the best mid bass. Right now, I have none. I have the HPF set at 80hz, and a HP slope of -6db. If I set the slope to the "Pass" setting, the mids put out too much mid bass and it makes a slapping noise. How would I go about setting it so that it puts out some decent amount of mid bass, but not too much that will cause the mid to distort?
eq boosts cause distortion, but will give better midbass. try the 120hz range.
crossover the mid lower, but your headunit prolly wont let you.
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
746
The intention of the eq is to create a flat curve if you have peaks and nulls. If you are competing for sq, try to get the sound as flat as...
688
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
You are going to need to beef up your sub stage in that vehicle to get that kind of bass response. A good pair of American Bass XFL 10s or 12s or...
JeffM
JeffM
NL, Canada
adam71
