Setup recommendation...like/dislike..what would you change or add???all inputs valued
  • 1
saleen_1985
I have a 2006 Ford F150 Crew Cab (4 full doors)...
Looking at re-doing my system and going with this setup....
Head Unit Kenwood Excelon DNX9980HD (double din, but might op with single din and doing away with Nav system and adding stand alone Garmin)
Front Comps - 6.5" - Hybrid Audio Tech (HAT) - not sure what model, Dynaudio 240 or 242 GT, CDT- HD-62US, ES-620, Hertz MLK-165 or HSK-165, DLS-UP6I...Looking for speaker that can handle ~ 300 watts rms/per channel...looking for crisp clear detailed, that is warm and smooth, not too bright or harsh....
Amp powering front comps - Arc Audio SE 2300, or keep my current Audison LRx2.500
Rear fill - currently have rainbow coax being powered by LRx2.250
Sub's - currently have JL Audio stealth box being powered by JL 500/1 and looking to add either two 10's or two 12's being powered by 1000 watts...Subs and amp I'm looking for suggestions or might just use JL audio 1000/1 pushing set of JL subs....
I listen to mainly old classic rock (Van Halen, AC/DC, Kiss, eagles, etc) and current country..
Do I need to add another battery, and alternator I'm not sure of current rating??????
Please suggestions on good head unit, 6.5 comp speakers, sub and sub amp... there are no high end car audio dealers around me so I can't audition anything unless I want pioneer, kenwood, sony,etc
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
708
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
984
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
saleen_1985
saleen_1985
Louisville, KY
saleen_1985
maylar
    Jun 2, 2024
    Jun 1, 2024
