should i put 6*9 in the back tray?
  • 4
it's a hyundai lantra 96
quite a large saloon
and i was told a 6*9 will make the sound more wide
but i know a sub and a comp should do, so i am really confused //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
anything?
anybody?
allso when i install the components, should i seal the door?
i dont have anyspace to build a pod inside the door
will the door be good enuff without sealing?
if i build a box inside the door it will block the window wouldnt it?
Leave the 6x9 alone. They will be good enough fill for the car. You don't want anything to drastic in the rear anyways as all you want is some fill. Get some good components stick them in kick panels if possible. Kick panels produce a much better sound than doors, but if you don't have room put the good components in the door. You might need a spacer if the speaker is too deep, just make sure you have a good seal around the speaker and the spacer.
The CT's are nice, That Sundown is a a frik'n beast!
7
719
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
634
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
725
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
8
DaviX
DaviX
Israel
dave_3148
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
