"Shove" Sub inverted.
  • 5
The sound is incredible!
I tuned the Amp first try 👊🏽.
Time for rebassed 28HZ!!
Thanks 👍
Thanks 👍
Looks like it gets down pretty good. Nothing better than being happy with the work put in. I always like to give a little space between the amp mounting surface to get some air in between the surface and bottom of the amp. I enjoyed the Vid man!!
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
253
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
407
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
515
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
829
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
531
Jake321
CarAudio.com Recruit
Jake321
Hawaii
audiobaun
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
