Simple sub size question.
The choice:
4 - 10" subs wired to 1ohm sharing 3,000w
OR
2 - 15" subs wired to 1ohm sharing 3,000w
Why would you choose one over the other?
In my mind. I’m thinking lot of things.
how much space do i have in the vehicle? What is the frequency response? Things along those lines.
Let’s say all things being optimized. I’m thinking the 4-10s would be better for daily driver. More cone area then 2-15s. While the 2-15s might be able to play lower in bass frequencies. Are the average guys going to be able to hear a 20 or below sound?
I almost pulled the trigger on a 2002 Grand Cherokee. But I did make up my mind. It will be a Grand Cherokee. I am running two 10's now that are going to be upgraded in the Elantra but in the GC I want to frighten people.
I'd do the 15's (if we're talking same subs but different sizes)
Most likely cost less
More cone area
effortless sound
easier box
What 15's are you looking at?
In my experience, larger subs play lower, so I'd go 15's.
However, EVERY teenager has TWO subs, so I like four 10's for the wow-factor.
Ultimately, I prioritize a pretty install with whichever route you choose
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
916
I went with those simply because they fit, the cutout is round, and the hole will take a 6.5 coax. Cutting a square hole in a boat for a speaker...
21
4K
I think you're going to find this is true across the board. Technology has come so far at this point that even the absolute rock bottom unit that...
6
No Issues out of my CT Sounds amps..EQ, 6.5s. There is not one company out there that hast ever had a perfect QC run that I can think of.Hard to...
8
I think it is the input sensetivity. Indicating you can wire direct ftom speakers.
21
3K
ThxOne
Premium Member
The Boss
ThxOne
The United States of America
audiobaun
Latest topics
