Single wire HO alt hookup
  • 2
oxsign
No Affiliation
6,046
34
Orlando, FL
So I have a mechman alt I used as a secondary in my old setup. New truck and I only need 1. Is it possible to connect and remove the battery light that will come on. Or is it even possible to use as a primary alt?
Truck is an ‘01 gmc 4.3.
Thanks for any help.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
652
976
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
oxsign
No Affiliation
oxsign
Orlando, FL
