Skar Audio RP2000.1… blown amp?
  • 3
Zpop
CarAudio.com Newbie
12
Chicago
Hello,
Recently had a shop upgrade my amp from a RP1200 to a RP2000 (including the 0 gauge wiring for power/ground). Have been bumping for about a week with this setup, and out of nowhere the amp has completely shut off on my commute home today. I haven’t even been pushing this amp and my sub to the limit, if anything I would have the bass knob cranked on lower volume and occasionally up the volume.
Today however, there was a slight smell from the amp and all of a sudden the amp was making a crackling noise and completely shut off. After some visual inspection I didn’t see anything wrong with it, I tried turning the car back on after checking the fuse in the engine bay and the amp doesn’t even turn on into protect mode.
What can I do here and how should I start? I’ll be scheduling an appointment with the shop I had it installed with but if there’s a easy fix I could do then I’m all ears…
Let me know, TIA.
In addition, the amp has a protect and power on light. Neither lit back up even after turning the car back on.
If you have a multimeter, check the power and ground wires. It should be ~11-12.6 volts. If you do have voltage, turn on the system and check the remote turn on wire, 12-14.4 volts range.
Do you have a Warranty on the Install? You should have a warranty on the amp from the shop. Take it back there so you dont VOID any warranties
Sounds like the amp got too hot and burnt up/fried to me.. You may need more power / bigger amp, or a better sub stage that you are expecting too much out of what you have
Shop was able to confirm the amp itself had an internal component that likely went out so I’ll be sending it back to Skar ASAP for a replacement. The installer himself said it’s one of the most common amps he’s seeing get returned, something about the RP2000 and the way they run they continue to crap out on people.
Id keep with the warranty return. Id look at getting a different more reliable amp, and maybe Sale the Skar.. Thats me though. Seems like a PITA if an amplifier isnt doing its job other than taking a dive and costing time and even possibly money if it ends up ruining your subs in the process of taking that Dive once again.
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
6
983
I usually build my own enclosures and didn't have the time to make another box, just happened to have the dual 12" box laying around. I see a 3.5...
6
  • Locked
COMPLETED Skar Audio RP600.5
sorry been on bed rest due to back issues. Looking for max depth of 5.5” 2ohm load 350 watts 1ohm load 500 watts
7
Bassbox pro requires many t/s parameters some of which arent on the skar audio website. This is my first time searching for t/s parameters online...
Zpop
CarAudio.com Newbie
Zpop
Chicago
audiobaun
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
