SketchUP '10 F150 dual sa-10's
  • 2
All you gotta do is own up to the fact that you reverse engineered the design then posted it as well... hey... might as well market it too... make some money off it while your at it... good luck man... I'm thru with advice for ya'... //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I did not try to claim your design, i was simply helping anyone else with the same problem I had with a supercrew. I appreciate you helping me tune the box and all, but in no way was I trying to market it lol
Might as well... you got a freebie... hey, a dual SA-10 ported underseat design for your power is pretty easy to come by huh?.. must sound pretty good too judging from your constant raves... enjoy it till you blow those subs or smoke your amp... you'll never get another word of help from me
Look man if it was that important than maybe we should have discussed that in the beginning. You mainly did the port tuning, I did all of the volume figuring and you know it. Anyways, im not going to argue over a box.
"Look man"... lol... I been told... //content.invisioncic.com/y282845/emoticons/plthumbsdown.gif.d7966af824c93c6021d1aae1778b1c19.gif
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
Thanks so much guys. Talked to crutchfield support with the same question and although they likely don't know everything, and sometimes, salesmen...
6
They really are. Fit to perfection! Sounds Good Stereo are the best.
7
apeterson26
Memphis, tn
apeterson26
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
