Slotted port displacement question
  • 3
K5BEAST
CarAudio.com Newbie
7
Earth
Where do you begin calculating the port displacement in a box design shown in the attached pic? Point A or point B or ??
Yep. Point A. The last 3/4 of an inch on the exit end of the port won’t count in the displacement though. Take 3/4 off your length. You also have to add the 3/4 wood thickness of the inside port wall. if your port is 4 inches w x 14 high x 30 long inside, your displacement math would be 4.75 x 14 X 29.25. For example.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
981
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
666
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
830
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
804
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
K5BEAST
CarAudio.com Newbie
K5BEAST
Earth
SlugButter
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
