Small 4-Channel Amp
  • 2
tb30570
Hello,
Do you think I should fix my MTX 404, buy a used RF 400a4, buy a new MB Quart DSC450 or buy a new Hifonics Txi4408?
I have an MTX Thunder404 with bad solder on the RCA inputs. I got the MTX because it's little and easy to fit in small places. This amp doesn't have as much power as I would like. I also have a Rockford Fosgate 400a4 in another one of my cars which is even smaller than the MTX and has better power output. I looked at a bunch of new amps, and not many manufactures make amps as compact as they used to. I've listed some of the new amps that are below.
MTX Thunder404
35x4@4-ohm (pre CEA-2006)
2.25x9.81x11.56
need to fix, not sure what cost will be or if I can fix it myself yet
50x4@4-ohm (pre CEA-2006)
2.60x9.60x9.70
used, not sure of cost
MB Quart DSC450
50x4@4-ohm (not CEA-2006 compliant)
2.70x9.45x11.02
$87 new
Hifonics Txi4408
55x4@4-ohm (not CEA-2006 compliant)
2.36x9.07x12.60
$115 new
thanks!
look on ebay for a bnib cerwin vega exl 400.4. its got 65x4@4 iirc. and its an arc cxl (or something like that) clone. same zeff designed board. basically the same components. solid amps. best bang for the buck bnib money can buy.
I appreciate the suggestion. I looked up the dimensions on sonicelectronix (2.20x9.20x15.00). It's a little longer than I'm looking for.
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
799
  • Locked
COMPLETED Small 4channel amp
I'm really tempted to grab a 4k db 🤔
19
3K
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
8
tb30570
tb30570
North Dakota
tb30570
Decebal
    Jun 10, 2024
