Snap Crackle Pop! Smoke. Help with deck!!!!
  • 1
rocca_dogg
More ThUmP in the Trunk
Ok here's the deal. I wired in the 12v wire and acc wire to my car and had it all hooked up to my deck. Well the last thing i connected was my ground. When I found a good piece of metal I touched the ground to it, it sparked violently and then my head unit started smoking! What the hell did I do? Did I just kill my new deck.!!!!!! Did I just blow a fuse??? What does a blown fuse looki like!
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Hello! i have too problems with head units, two cars, old mazda 323f ba and now mazda 6 2007r station. Problem is from lossing quality, poor bass...
988
This will be an interesting issue to find out. Subscribed!! Are you running components? Ive had some caps blow in Passive xovers and a little...
967
Well, I found a way to "fix" the popping. Ran a separate remote turn on from an acc fuse to turn on only the amps. Still using the LC7i GTO to...
rocca_dogg
rocca_dogg
Coeur d' Alene
rocca_dogg
    May 18, 2024
    May 18, 2024
