somebody help....need some opinons
  • 2
Really kind of depends on how much bass you can handle. The A7HC should be able to provide enough juice at 2ohms to really push the kicker a long way. Adding another sub, obviously would increase the actual bass output and utilize the full power of the amp. The cadence is actully capable of far more output than its modest rating states- either way you should have quite the SPL monster!
Take it easy,
-zane
140
444
421
quoiry
quoiry
hotmail.com
zane
    Jun 1, 2024
    May 31, 2024
