sound system cuts out.. HELP
  • 3
johnthompson
hey guys, I had a system installed back at the end of june at Horizon Motorsports. Anyways, here is my setup. lc-6 converter to an alpine mrx v70 amp. all alpine type s 6x9 speakers in the doors and a memphis audio 10 inch sub. Here is my problem... My system has been cutting out and at the moment hasnt even worked the past couple days. I checked to see if the amp was still on and it is, and is cold to the touch. anyone have any idea what is going on?? power wire is 4g and so is the ground wire
i had a similar problem where my amp would cut out at high volumes. i replaced the rca's and havnt had a problem since. theres many things it could be though.
hmm.. mine doesnt matter what the volume is at. and if it were the rca cable then the amp would be warm from trying to push power right?
i would think so, but im not 100% surr to be honest. it would make sense your amp needs a signal from rcas to push power. it doesnt get warm that would leave me to believe its not getting a signal from your rca's which is further evidence of bad rca's. but I'm not 100% sorry. the rca wires is the fist thing id look at. make sure all your wires are secure.
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
4
871
thats good to hear that sub/amp is good pair, well one of the front speakers on right side, im guessing it blew out because its the one that makes...
5
So I am planning to build a system in my Ford Excursion and can’t decide on whether I want to use an iPad mini with a sound processor behind it or...
johnthompson
johnthompson
Canton, Ohio
johnthompson
Decebal
    Jun 10, 2024
