Which amp should I get?
  • Total voters
  • 3
tpatten12345
I am looking to get an amplifier to power a polk mm6501 component set. they are 2.7 ohms and they will take 125 rms. I would like to get an amp that is either just right or has a little headroom. the amp only needs to be 2 channels or 4 bridged.
I was looking at one of these:
Rockford Fosgate t400-2
Polk Audio 200.4 bridged
Alpine MRP-F300 bridged
I would like to spend less than $175 (ebay) but could go up to 200
which one of these do you recommend or can you think of something better for the price?
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
364
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
331
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
You tried the external relay with no success? If so, how did you wire it?
18
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
tpatten12345
tpatten12345
Gorham, ME
Kal1877
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
