Speaker and amp helppp
  • 3
Sergio31
I have 2 12" jl audios and a rocksford fosgate amp in my truck it works perfect (my amp is designed for only two subs) meaning it only has two ports of negative and positive , but I recently bought 2 more subs 2 10" xplods and not knowing if I can wire two amps I wired them into my rf amp ( two subs to each port it sounds great but when I check my amp it's really hot I wanted to know some advise on what to do
sell me the jl before you mess them up
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
621
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
530
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
You tried the external relay with no success? If so, how did you wire it?
18
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Sergio31
Sergio31
Farmington, nm
Flex68
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
