Speaker and amplifier wiring help
  • 2
ntlazarus
Hi everyone. I have a Kicker amplifier (100 W RMS x 4 @ 2 ohms or 50 W x 4 @ 4 ohms). I would like to power a set of 25 W 3.5” dash speakers, a pair of 100 W Clarion 6x9s in the front doors, and a set of 75 W 6.5” Kicker coaxials in the back door. I currently have the 3.5” and 6x9s on the front 2 channels in series. I’m assuming that since they are wired in series, each channel is running at 8 ohms with each speaker receiving a lot less power than they can handle. I thought about powering the 3.5” and 6.5” rear door speakers together, since I don’t use the fade, though this probably won’t be a huge improvement. Does anyone have any advice on the best way to wire these speakers to achieve the best power output and sound quality? Is there a way to power speakers differently when connected to the same channel? I’m also open to changing the amplifier at a later stage. Thanks for any advice.
If it were me..I would use ch 1&2 /front to power up the 6x9s and use ch. 3 &4 for rear speakers and forget about the 3.5s temp, until you get a small amplifier to split off of ch 1&2 to power those up, or off HU with a Bass cap . I feel like You will end up blowing those 3.5s hooked up at the 2 ohm load off either front or rear
for my amp ground I have it to the paneling in my trunk, secured with a bolt and a nut. I sanded as much as I could, and I used a grind wheel on...
72
6K
Hmm. Maybe so. Ive never been more alert driving/riding than being on a Cycle man. Several think you just get on and ride away. A good set of...
26
5K
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
433
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
420
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
564
ntlazarus
ntlazarus
Atlanta, GA
audiobaun
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
