Speaker Buzz After Installing Amplifier
I'm using cruthfield brand 4 ch rca cables, they seem pretty high quality, also, does the same thing with a different pair of rcas ran outside the car. I've pulled it out almost every time I've messed with it, moved it around, moved the wires around. No change.
I hope you have their cheap cables, which are shielded. There is a tendency with RCAs to go unshielded with their higher end cables, which of course is bad juju.
these are the rcas I'm using from them. I don't see why they wouldn't be shielded.
Goes between the HU and amp. You'll need 2 of them.
just exchanged the stereo for another unit after checking everything. I still have the same issue. What else do you think it could be? If I'm using an external amp, I can just use the power and ground in the stereos harness right? to hopefully eliminate some interference.
151
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
322
439
363
EmpiricalApe
CarAudio.com Regular
EmpiricalApe
North Carolina
EmpiricalApe
SPLBassJunkie
    May 21, 2024
    May 20, 2024
