Speaker choice for big build
  • 4
For doors I'm biased. I'm currently running Dayton Audio mids (1 8 and 2 6.5s) with eminence highs (2 tweeters and 1 horn). Only in my front doors. Back doors are empty
I'm planning on going with one 10" midbass at the base of each B pillar at the corner of the wall and one 8" midbass and two 6.75" midrange, per door, a 6.75" midrange per kick, two 3" midranges in each corner of the dash, at the base of the A pillar, and two 26mm silk dome tweeters per A pillar... It's a mix of Pride Audio and CDT Audio. With Polk Audio amplifiers, and a Genius Audio DSP.
Dammned!! Be loud as Hell!! 💩 💩 👀 👀 Dropping some Dough Yo fo sho
I word of advise though, DON'T put the speakers "IN" your doors. Build sealed door panels to mount them in, or you will be launching front stage speakers non stop, from the sound wave(pressure) off the subs, getting behind them, inside the doors.
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
266
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
362
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
331
KicktheSDbasshead
2 builds 2 feet
KicktheSDbasshead
San Diego
KicktheSDbasshead
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
