Speaker impedance
  • 2
DLJ
Hola. I've got an intriguing wiring question involving speaker impedance (redundant, I know).
Okay, I have two audio channels. Seven speakers. One demux.
Two of which are wired together in series, wired into the demux in parallel.
Another two in the exact same set up, together in series, to the board in parallel.
I have two wired in series, then to the board in a bridged parallel (positive on one channel, negative on the other).
I then have one speaker bridged in parallel (positive one channel, negative other).
So, how do I go about measuring total impedance to each channel? Since.. You know, if you count the two speakers in series and bridged as one speaker, I have two speakers bridged, in which case I can't measure TOTAL impedance on one channel. So.. Uh.. Yeah, any ideas?
I don't have the individual speaker ohms handy, I can check them tonight.
Use a dmm to test the resistance once you get them
793
I went with Kenwood Exelon. Audio Control amp and speakers. It’s amazing! I’m glad I did some research before buying. Thanks guys.
5
616
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
491
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
654
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
560
DLJ
DLJ
Aurora, CO
05trailblazer
