Speaker wire disconnects
knotdrummer88
I have a 1998 jeep cherokee, and when the weather breaks in a couple months I will be making my front doors removable. Now in my front doors I have 2 mids and one super tweeter in each door. From the doors I have one run for the tweets and one run for for the mids. Now, when I remove my doors what is a good way to make plugs for the speaker wire?
I have a 98 cherokee as well. Are you using the stock speaker location?
Well, they're in the stock location in the sense that they're in the door. They are in fiberglass pods, and I also have two of the same sized mids built into the sound bar
If you have a passive x-over connected to the speakers from a single source you'd have to place dummy resistors in place of the speakers if you're going to use your system.
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
913
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
knotdrummer88
knotdrummer88
Toledo, OH
whitedragon551
audiobaun
    May 19, 2024
    May 19, 2024
