Speaker wire extension
  • 3
pghram1500
All, I am going to be installing an LOC in my daughters car. I want to place it in the trunk for easy access to it. Would it hurt to tap into the rear door speakers and instead of placing the LOC in the B pillar, but instead I tap into the wire and run additional speaker wire to the trunk then hookup the LOC and AMP right there. Should cause no difference correct? So much easier to power LOC with AMP 12V positive and negative.
Im not sure i totally get your question but it doesn't matter where you get your 12 volt power as long as whatever fuse is connected between that wire and the battery, is rated for the combined load and that wire is large enough for the combined amperage pull. Im not sure LOCs in general have much of a amperage pull though so that shouldn't be an issue
You can probably use your rear speakers as your left and right LOC inputs however your stock stereo may not have a full range signal going to them.
Sent from my SGH-M919 using Tapatalk
i don't see y it would make a diff.. mine was in trunk but ran off rear deck speakers but i don't see y longer wire to loc would matter
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
907
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
8
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
11
pghram1500
pghram1500
Pittsburgh, PA
BOOMINGRANDPA
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
