Speaker wire gauge and subwoofers
  • 4
cool9
France
Is there a chart for speaker wire gauge vs. subwoofer power? I have a 200 RMS/400 W Max subwoofer being bridged by a 2-channel amp. What gauge wire should I use? I've never had a subwoofer before.
My subwoofer (10" RF) also has a spring-loaded speaker terminal. You stick the wire in and the spring clamps it down. Except the spring is really strong almost to the point it feels like it'll cut the wire that's inserted inside.
it won't.
i'm a big fan of 14 gauge myself, seeing as you can buy a 50 foot roll of the stuff for 10 bucks at walmart.
12 guage is probably the best as far as speaker wire goes. You'd likely have to buy power wire to go any bigger than that.
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
910
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
8
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
11
cool9
cool9
France
audiobahnuser18
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
