Speaker wire polarity
  • 3
Hardworkingman32
CarAudio.com Newbie
I have a speaker wire, but its not labeled at all. One has just silver on one side and the other side has copper with a very small strip of silver in it.
Which one of these is positive and which one of these is negative. There is no labeling whatsoever, no stripe. Nothing at all. The copper+silver seems more twisted and than just the silver. I want to make sure I have proper polarity setup for my sub.
Its whatever you make it
I usually make the copper side positive but to each their own
Whatever wire you attach to the positive on the amp goes to the positive on the sub same thing for negative
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
953
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
8
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
11
Hardworkingman32
CarAudio.com Newbie
Hardworkingman32
Nashville, TN
AnthonyO
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
