Speaker Wire question
I have 2 FI Sp4 18s and I am going to be getting 2 Crescendo BC3500s. I know this might sound like a dumb question but 8 Gauge speaker wire is what I would need for this right? I do not need to use 4 gauge right?
ALWAYS use the maximum allowed input gauge. I use 12g for all my speakers and subs. If your talking about power and ground however for the sub's your running I'd say a minimum of 4g. Like I said use the biggest wire allowed to be used or can fit.
O gauge is the minimum for anything over 1.5k/1.6k. He also said speaker wire never mentioning power and ground.
Op 8 gauge sub wire should be fine as long as your runs are shorter than 8 feet.
I do all my posting on my smartphone. I could of swore I read 0g when I proof-read. 16-18g is fine until you hit around the 750+ watt region - from what I have learned. Then bigger gauge wire would be more suitable.
Alright but for the fuses they will be the ones right off of my battery under the hood? A 250a fuse should be fine for that correct? I will have a 320a alt and 0 gauge.
Yes 250-270 should be fine lower will pop sooner so makes it safer I wouldn't go higher than 270 imo.
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
8
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
945
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
11
Mercede
How it was
Mercede
Alaska, United States
Mercede
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
