speaker wire too big for push connectors
  • 3
mrtonytompson
Hey, im trying to wire my hds315 down to 1 ohm using 12 gauge speaker wire. Only problem is it is too fat to fit. Can this cause distortion if all of the wire cannot fit in the connector? Just got my sub fixed from soundqubed and its making a rattling sound at any volume. What should i do?
the sub is still making the rattling noise after being fixed? and am I guessing right that your doubling up the 12 ga? Wait till you get to the one where you have to triple it up lol. Im looking into some "tee" type connectors as I feel your pain with this
if the wire is shorting to the metal case of the woofer or the other terminal then yeah you'll get distortion.
otherwise definitely not, if you get the majority of the wire in there it's going to make a connection and keep it unless the wire is pulled out. if theres a couple strands of copper sticking out the sides its not going to change anything considerably besides raising the resistance by a very minute amount
Im going with this
with a bolt into the push terminals. then tighten a nut down on a few of these and running it off to the 4 sets of vc's
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
912
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
8
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
11
mrtonytompson
mrtonytompson
Lansing, MI
mrtonytompson
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
