Speakers cutting out!
  • 1
Greetings,
FNG here! I just joined to gain some knowledge concerning an issue I'm having with a new installation.
I installed a Pioneer DEH-X3900BT CD receiver in a GMC Savanna. I used an adapter to connect to the factory wiring harness. I also installed (2) JBL GTO638 6.5" 3-way speakers in addition to (2) Pioneer TS-G1645R 6.5" speakers.
The problem I'm having is after running on auxiliary for about 5 minutes the speakers crackle and fade out. In another test, I started the engine and when I turned the headlights on the sound faded immediately.
I'm guessing I need a separate amp to drive the speakers. Advice?
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
261
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
205
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
376
ProCarpentry
ProCarpentry
Lynchburg, VA
ProCarpentry
