specific hardwiring instructions??
  • 3
cazorp
I have an 06 stang, and i have decided i want to hardwire my radar detector to my car, can anyone give me some advice on how this can be done?? the more specific the better. I will probably hard wire my playstation too if the radar detector works ok.
thanks
Zach
all you have to do is find a solid ground point,and drop your under dash panel on the driver side and find the ignition wire,that way you power your radar when you start our car,as for the play station i recommend using a power invertor,wire that to the battery,and use the swith on the invertor to turn it off and on,also dont foget to install fuses,when you connect your wires to power.
Youll need a Honda Civic reverse radio wiring harness and 20 toyota radio wiring harness ...match colors of wires and shes ready to go...
Check your grounds! Both head unit and amp. I had this issue before and it was a grounding issue. Ground wire made enough contact to play low...
cazorp
cazorp
Shreveport,LA
houston281
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
