SPH-DA360DAB brightness issues
  • 2
mlirog
CarAudio.com Newbie
latvia
Hi there,
I just got my Pioneer SPH-DA360DAB for my 1999 BMW 530 ( aka pre-facelift BMW E39 ).
I hope you all know that Pioneers have "day" and "night" display brightness mode for headunit. For some reason once i enable auto-detection for these modes, these modes jump back and forth every like 10 seconds. That happens if the lights are are turned on to day lights or low-beams ( dont know the correct names for them in english.. anyhow.. not a "zero" position ). But if i do leave it at zero position, my headunit stays at "night" brightness mode, well, obviously i cant drive like that in the night.
Are there any workarounds for this issue ? I assume thats because of my pretty old car and as i believe, headunit auto-detects those brightnesses by some wire behind the unit itself.
Factory speakers have a low power rating so it does not take much to get them moving. Aftermarkets have a higher power rating so an amp will...
Thank you skyhawker. The head units installed in the car go up to only 88 Mhz to 108 Mhz. FM stations. Million hertz. Wifi goes up to 5 Billion...
4
Well, the odd thing is, page 3 of that manual shows the left socket as the rear view input, mute, and steering wheel control. While the right side...
I'm not sure if you can run a usb hub off a hu
mlirog
CarAudio.com Newbie
mlirog
latvia
Louisiana_CRX
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
