square body chevy under seat box
  • 1
racin69z
My son daily drives a 86 chevy regular cab full size truck. With subs behind the seat, there is no room for storage. The cab is built with two large humps under the seat for the side saddle gas tanks. I am going to relocate the tank to the back between the frame rails where a blazer tank would go. Then I can recess a box into those humps and put a sub under each seat.
I am not looking to win any contest, just want to have some nice thump for classic rock, and classic country type music. I am thinking about 300w rms and a couple of fosgate prime 10" subs. Since the box will be partially recessed, I cant really down fire unless I completely rethink everything. If I up fire the subs will it sound like crap if they fire right into the seat bottom?
I could make a chamber that goes over the sub that is kind of the reverse of a down fire setup that would direct the sound behind the seat if that makes sense. I think that would be kind of a band pass type setup and I do not know how to design such a deal.
Any thoughts?
Thanks
Lynn
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
11
Contact ANS he has a used Focal 8 Channel DSP that went for 1,300 bucks and is selling used I think shipped for 450. And from what I have seen and...
13
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
12
687
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
5
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
racin69z
racin69z
Jackson MO
racin69z
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
