starter current pull on honda
  • 2
lostforawhile
28
georgia
anybody know what the starter pulls on an average honda? i have an 86 accord with the 2.0 so it pulls a bit more then a regular honda, i am relocating my battery so i want to add a main battery fuse, but i need to figure out the max amp draw of the starter. the cable is fine,i am using 2 gauge aircraft battery cable,exotic stuff, but plenty capable.
You would fuse it according to the wire capability not the current draw.
2 ga, probably 15-18 feet. You couldnt go wrong with 200-250 amp fuse.
yea i have heard in cold weather our starters on these old accords can pull up to 350 amps. i was going max current draw to leave some safety room in the wire. going to put in an odyssey battery and it can produce over a thousand amps on short circuit,so plenty capable of popping the fuse in a short. i don't have a huge system, do have some current draw,but the 2 gauge would be only running at max maby 60 amps when the car isn't starting. and thats absolute max.
If it really will pull that much current you may want to upgrade to 0 gauge. But try it and see. If it blows the fuse you need to upgrade.
Thanks for your response guys! I'm not so much involved to justify an LTO,car is a daily driven and batteries will be installed when needed.Maybe...
Class A/B, right? If I recall, these little 2x30 watt jems could best several hundred watts, mono. One of RF's endearing qualities on most of...
870
Yeah i Yeah I know. I have my sub wired at 4ohm so I can get 300w rms from old amp. It’s 1000w max. And yes that’s the reason I got this pioneer...
40
4K
I like the MA Audio HK series ..ive ran and won with them at car audio comps
If you have not already done this, do a thorough job of sound deadening the doors before spending a lot of money new equipment. This is probably...
lostforawhile
lostforawhile
georgia
mokedaddy
