Steering Wheel Controls Theory (Will it work?)
  • 1
qtipextra
The Original
I just purchased a 2012 Dodge Ram 1500!!! Now I want to figure out my Audio system and setup.
The plan: Single DIN Pioneer receiver/head unit for audio control, with a 7" Android tablet connected to the Pioneer's AUX input.
I would like to use stock steering wheel controls of my truck. I want Volume and Source buttons to be sent to the Pioneer. I want Track and Pause buttons to be sent to my tablet via a USB interface.
First, I've found out that I need a CANBUS adapter to convert the steering wheel control's CANBUS signal to an analog signal, correct? Is that output considered resistive?
So far, here's what I've come up with for parts/modules.
#1 - PAC SWI-CAN2 Interface (For converting CANBUS signal): Link Here
#2 - PAC SWI-RC (For outputting to Pioneer's wired remote input): Link Here
#3 - Joycon EXD USB (For outputting commands via USB to tablet): http://store.mp3car.com/Joycon_EXD_N...p/com-171b.htm
I can program only the Volume and Source buttons via the SWI-RC's learn mode so that no other commands are interpreted by this module, which will be sent out to the Pioneer.
I can program only the Track and Pause buttons via the EXD USB's configuration so that these are sent out as keyboard input to my tablet via USB.
Essentially, it would be configured as follows:
Can anyone see a reason why this would not work?
Not enough information. Some remote units are radio specific while others are stand alone.
thanks for your time in replying and the effort you have obviously gone to, my radio only has just one single wire for the steering wheel control...
4
Did the instructions on the back of the main module not work? They are vague but give you a general procedure.
Update: I emailed Atoto support. They are asking me which wire in this Simple Soft CAN BUS controls the steering buttons? If I knew that, I...
That might depend on the head unit. Some can use a 5 amp fuse, some a 10amp, some a 15amp fuse (if / depending on how much it's powering the...
5
qtipextra
The Original
qtipextra
Idaho Falls, Idaho
qtipextra
