Still looking for 750-1000w rms amp under 200
oh you dont need power at 2 ohm than there are millions of options, that boston g28 is ridic low priced. i would jump on it
Refurbished Cadence Z1200 Class D 2400 Watt Competition Monoblock Car Amplifier | eBay
Soundstream RUB1 1000D 1000W Class D Monoblock Amplifier 709483032385 | eBay
the rubicons are their top line and a much better option if your set on soundstream, chinease made. the cadence is much better usa made and more effecient
Lanzar OPTI1400D Optidrive 1300 Watt Mono Block Digital Competition Class Ampli 68888725682 | eBay
usa made amps also better option vs soundstream
Precision Power PPI S1300 1D Mono Class D 1300W Sedona Amp Amplifier AAA Class 709483035980 | eBay
MB Quart DSC1000 1 Discus Series 1000W Class AB Car Stereo 1 Channel Amplifier | eBay
for under 150 this is your best option, mb quar dsc series
MB Quart Onyx ONX1 1600D 1600 Watt Mono Block Car Audio Class D Amplifier Amp | eBay
for effeciency and quality the boston gt-28 mentioned would be my first choice. it italian made yummies. but next would be the us made cadence z1200. super effecient and and underrated amp. i have seen 1400rms plus benched out of them.
Boston gt28 $150+ship...1.2k+@2
That Boston GT will kill anything mentioned so far.
What about the Hifonics 1500D? I heard that the HFI series doesn't do rated power, then i've heard they're under rated. i would definitely pick that up if it did rated, but i'm unsure.
Thanks for the post GVP. I'll look into it.
someone just had a MBquart onyx for 125 shipped in the classifieds. cheap power /thread
im looking for about the same power same price range as OP, i have a question.
Would the Gt wired down to lets say 1ch. @ 4 ohms doing 900w pull more draw then a monoblock doing 900w @ 2ohms? Im trying to be conservative on my electircal and keep under 1k watts aswell.
Toyota is really efficient. Usually the life of a Toyota last 18 - 25 years before the car or truck begins to wear down. 25 years then fixing...
16
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
11
added a 32AH bank to my system...... Cot damn! Now we rockin. Voltage staying above 13 wide open!! Just thought I'd update.
4
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
3K
Before you remove the amp, swap the front RCAs with the rear ones on the amp and repeat the test. Many guys here use the Pioneer amps and love...
akillj
akillj
CA
mclerico83
