Stock HU, Right side of car doesnt play.
  • 4
Moofs
I currently have a 2003 Maxima with a stock non-bose stereo system. Everything was working fine until I went into a restaurant, bought some food, and when I turned the car back on after I was done there was no sound coming from the right side. Its been this way for about a week. What could have caused this?
I currently have all the equipment for a full system, which I have yet to put in. Which makes me wonder, will this issue effect my system install? If I had a new HU, amps, etc. Is it possible this issue with the right side can persist? What do you think it is?!
maybe a right side speaker wire was grounding out and fried the right side?
This. Happened in a friends truck and I told her not to turn it on until it was fixed bc it would work sometimes but most of the time the whole right side was dead. Turned out to be a bad ground and bc she didn't listen, fried all but 2 speakers. It's possible it could be the right channel in the wad unit as well. But either way, you can fix both issues with your system install.
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
757
920
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
592
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
682
Moofs
Moofs
Chicago, IL
ssteele18
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
