Strapping amps issue
  • 2
JEXTEL
Heres the layout for now
alpine cda 105
clarion eq
4 18 fi n2's wired to 2ohm
-27cuft NET
-3 8" aero ports
-27hz tuning
2 crunch gp3000ds strapped
-subsonic set to about 20hz
problem is it doesnt play the lows as voilent as it did with 1 amp 43-44hz(Sounds peaky compared to1 amp also) is loud but it kind of fades off below that..still moves some air but not like it did on 1 amp at .5ohm
Also i have to take a look at the slave amp for the settings(subsonic) but im pretty sure they wont matter since its in slave mode
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
412
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
548
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
JEXTEL
JEXTEL
Bridgeton, NJ
Buck
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
