Sub/amp question
  • 3
twisted001200
I found a JL w6 for really cheap so i picked it up today. I already have a Sony xplod amp hooked up in my car from my old system, would this amp work for the jl w6v2 d4
Sony XM gtr2022'
Response Bandwidth 5 - 50000 Hz
Max Output Power / Channel Qty 400 Watts x 2
Continuous Power / Channel Qty 202 Watts x 2
Amplifier Output 2-channel
High Level Inputs Yes
Input Signal Voltage 0.3 - 6V, 1.2 - 12V
Crossover Active crossover
Crossover Slope 12 dB/octave
Low Pass Frequencies 50 - 300 Hz
Bass Boost Frequency 40 Hz
Bass Boost Gain 0 to +10dB
Output Power / Total 1200 Watt
Amplifier Output details 202 Watt - 4 Ohm - 20 - 20000 Hz - THD 1.0% - 14.4V DC - 2 channel(s) 250 Watt - 2 Ohm - 20 - 20000 Hz - THD 1.0% - 14.4V DC - 2 channel(s) 500 Watt - 4 Ohm - 20 - 20000 Hz - THD 1.0% - 14.4V DC - 1 channel(s)
Additional Features Input level controls
Connections
Connector Type 1 x audio line-in ( RCA phono x 2 ) 1 x audio line-out ( RCA phono x 2 ) Speakers input Speakers output
Universal Product Identifiers
Part Number XM-GTR2022
UPC 0027242721159
what size is the w6?...but xplod amps kinda **** if there not powering xplods subs...i have 2 12" 1000watt xplod subs,1 800watt bridged(subs) and 1 600watt(speakers),xplod head unit,xplod speakers all around and its sounds awesome iv won 4 bass comps. in the 2 sub 501-1000watt class with this system...but iv powered my 2 1000watt audiobahn 1 i2's with the 800watt xplod amp and it sounded ok but way better on the xplod subs.....so try to go with matching equipment if you can
but i dont see why the xplod amp would hurt the w6 just dont turn the amp up all the way and blow it
The sub is a 12" . yea i know im going to be getting a new amp soon, i just wanted to make sure it wont be bad if i hook the w6 up to this amp. Is it going to sound shitty with the amp?
i wouldnt say shitty but it wont sound as good as if it had a JL amp on it that matched the sub ya know what i mean...just hook it up and see how it sounds and if you like it then keep it in if not keep it untill you get a new one
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
765
213
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
837
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
9
869
twisted001200
twisted001200
california
x2o
