Sub and Amp to match a Gladen 100.4 DSP
  • 3
DeruDog
24
UK
I am designing a system for a 2012 VW Passat to listen to acoustic music on my commute. Some blues and alternative also. My top choice for an Amp/DSP is the Gladen 100.4 which, you guessed it, puts out 100W per channel to 4 6.5 component speakers.
I will design a sub-box to go under my rear deck, and think I want a 10" sub for this configuration. Not sure which one to get and what amp to power it with. Budget for the SW/amp is about $400.
Sorry for the confusion: looking for the correct sub and amp to match the 100.4 with 6.5" component speakers. Not looking for 2000W amp and 3x14" woofers, for example. Also not looking for 50W amp with a 6.5" woofer. What is the correct sweet-spot in between for the music style I mentioned? Acoustic, jazz, blues. I imagine I will be looking at a 10" SW at about 300W? Would that be right? Also, not sure whether to go with a $200 driver and a $200 amp, or some other thing. Any brand/model advice is most welcome.
https://audiolegion.com/collections/monoblock-amplifiers/products/al1200-1d-1200-1d-monoblock-car-amplifier
7
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
550
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
665
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
9
662
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
DeruDog
DeruDog
UK
LosIsATool
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
