sub connection thru box
  • 6
i'll just go with the stainless bolts , for easy box removal from my blazer . thanks
Yuppers....easy disconnect
I've used all 3 methods. I will warn you, if you use bolts make sure you secure them very tightly. They will get dangerously hot if they loosen up.
To an extent. I could hear the wood crunching while tightening mine so I stopped. Might add to use loc-tite....if it's ideal in this situation.
Yes on both of these. Splicing means connecting one wire to another. So one wire to the positive and one to the negative wires or terminals of...
8
911
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
138
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
234
I've been a fan of the JL shallow mounts, and have actually heard a decent box with some Pioneers but the Focal are pretty darn good. The JL TW's...
7
294
02Blazer
02Blazer
San Diego, Ca
Boomin_tahoe
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
