sub help!
  • 2
Carlton
i got a system in my car about 2 weeks ago and 2 days ago while listening to music not even loud my sub stopped kickin i've checked all the wiring and fuses n i dont think i could have blown the speaker or amp they look fine and now n then my sub will hit just a little bit.. all help appreciated..
ok. my idiot friend said he looked at the fuses. so nvm the two 30 amp fuses on my amp are popped.. but new question. why?
How does that make him the idiot? Sounds like he has much more common sense than you.
So you have an 800 watt sub (1600 ios a peak spec, ignore it) the SVR-10 - 800 RMS dual 2VC ohm wired in parallel for a 1 ohm load paired with an...
7
81
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
3K
2400w x 4 peak and 120w rms x 4. That has to be world record dynamic right there 🤣.
28
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
3K
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Carlton
Carlton
Janesville,WI
Ge_off_me
Dylan27
    May 19, 2024
Dylan27
    May 18, 2024
