sub noise
gordos420
well this is happening in my cousins car...he turns on the radio and the subs sound like they are playing a sweep but when he steps on the gas the subs go back to normal..i tried changing the ground...i flipped the rcas to make sure it wasnt from that and that still didnt work..what could it be?i was thinking either the amp or the cd player but it only happens with the subs and not the 4 channel amp
the ground is probably 2 feet at most..all the wire is 4 gauge and the amp is a kole 1440/2 or something like that..but he bought the car with everything in there and its been good for the past 5 months..but his headunit is some old panasonic cd player..i dont know what model it is..i would have to ask him
i would replace the sub amp. sounds like it's more then likely a bad amp.
245
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
563
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
590
gordos420
gordos420
Chicago, Illinois, United States
SethPhillips
Decebal
    Jun 10, 2024
