Sub placement question
  • 3
Toomanytoys
CarAudio.com Newbie
14
4
I’m going to build a box for my 2011 Lincoln Navigator. The box will sit behind the third row seats in the passenger side corner. The question I have is which direction should the sub and port face? I’ve seen the sub facing up with the port to the side and I have seen the sub and port both facing to the rear. Which setup is better?
I’ve always had the best luck with port and subs on same side of box facing the rear. You might need grills or something to cover subs if you still want to throw stuff in and around the box. 4th order Bandpass with single port firing directly into corner works extremely well and subs are protected extremely well...but you have your traditional Bandpass drawbacks.
I've been a fan of the JL shallow mounts, and have actually heard a decent box with some Pioneers but the Focal are pretty darn good. The JL TW's...
7
207
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
194
Defiantly. LOL 😂 It has never happened to me👀:poop:
6
289
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
530
Toomanytoys
CarAudio.com Newbie
Toomanytoys
DFW40
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
