sub question
ccab
For The Horde!
Aight...I have two type r 12"s in a custom ported box..my friend is going to trade me his 1 AQ 12" for my iPhone..should I sell the AQ sub or keep it and switch it out with the two type R's? if the AQ sub willbe louder I want to put it in my car but if it wont then im gonna keep my type R's and if I do put the AQ sub in there how many ohms can I wire it too? what do you guys think?
and I also bought a 4 channel amp to hook up to my extra mids and highs in my car...can I not just run the rcas from the amp to the head unit and run an amp kit and them play the music instead of doing a distro block setup? my head unit has 3 sets of rcas..so I should be good shouldnt i?
how much power do you have? aqs like 1200+ if they are hdc3
usually more cone area is louder so the type r's would be. but i love the hdc3 myself and i would run just that. just for amazing people on how loud a single sub setup can get
and your second question made no sense
okay forget about the subwoofer part..I just need to know about the amp part...I have a 4 channel amp and I want to wire my extra speakers in my car to the amp...whenever I hook up the amp can I just run rcas from the amp to the head unit and run a regular amp kit or something and be fine? or do I need to do a distro block setup...some guy at the local shop said something about a distro block setup......
its fine but retarded. if you already have an amp then just use a distro block on the current wire. should be 0/1 already since you have an aq1200.
770
I would run a pair of 15s in an suv.. or run 4) 12s
24
1.25 NET cubes. You have to add the sub and port displacement to the box. I'm guessing that you will be around 1.7 net before sub and port...
I swapped out a water-damaged amp from a '73 Mercury Cougar and wired four speakers (2 frnt Door/2 rear door panel) as shown here, but did not...
ccab
For The Horde!
ccab
Southern Georgia
manny1337
