Sub suggestion for mtx slh12u
  • 3
bloedboer
CarAudio.com Newbie
Sub suggestion for mtx slh12u enclosure
I am currently running a kicker cvr 12d4 in a mtx slh12u enclosure on a rockford r2-500x1. Amp is certified at 636 watts rms. I am thinking about replacing the kicker cvr with a sundown e12 v3 or a DD 612e. Sundown rated at 500 rms and the DD is rated inbetween 500-800.
I think my question is what to expect sq/spl wise changing from one to the other?
Currently the kicker is playing about 236 rms more than rated for but seems to do allright. Amp was tuned with 40hz -5 db and rockford’s clean setup.
Link to the enclosure: https://www.mtxaudio.eu/products/slh/
Thanks in advance!
Prefab boxes are horrible and if they say 36hz I and others would be willing to bet it is closer to at least 40hz if not higher. Subwoofers always do better in a box designed exactly for them vs some prefab that is a universal setup. And if you are sticking to a single subwoofer then a D2 would be better IF your amplifier can run at 1 ohm so you can get more power out of it.
Also looking at that link the one box says 38hz so yeah figure higher then that if MTX is putting out those specs on it.
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
130
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
284
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
462
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
573
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
903
bloedboer
CarAudio.com Newbie
bloedboer
The Netherlands
bloedboer
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
