Sub will not turn on
  • 5
Oh, yeah, works fine in II and Run.
Except that then I do have entire dashboard running. And I just can't do it, constant fear of draining battery.
Oh, yeah, works fine in II and Run.Except that then I do have entire dashboard running. And I just can't do it, constant fear of draining battery.
No offense, but if you're worried about draining the batter you shouldnt be listening to your system with the car off. The amplifier is going to draw a decent amount of current...
247
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
565
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
593
ukrkoz
ukrkoz
wa
ukrkoz
Decebal
    Jun 10, 2024
