Subwoofer help
  • 2
ever put yer hand on the amp after it shuts off?? can it cook an egg?? I know pyle cant really put out that kind of wattage even if it was close to that amount and being that small of an amp the heat dissipation is poor at best.
here is a good site to help you with calculations http://www.bcae1.com/wire.htm
here is a good site to help you with calculations WIRE
yeah it gets pretty hot thanks for the help and the idea for cooking an egg
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
944
So the car audio shop I took it to just claimed "bad wiring" and now it all works. Not really sure what that means but case closed! thanks...
14
You can't really set it to a specific wattage. What head unit do you have? Find out the pre-amp RCA voltage. Most amp gain knobs are based off of...
7
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
11
zabzu
zabzu
iowa
zabzu
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
