What bass to choose for 335i
  • 4
nexusdoan
Hi Everyone -
I have stock 2009 BMW 335i setup and would like to add a subwoofer.
Something that has a strong preference towards electronic music.
A couple questions:
Does the BMW unit have an output for an external amp?
What kind small form factor pre-made sub should I go for? I was looking at the short almost flat ones. They are going for about $400.
It's a convertible so space would be taken up for a tradional ones.
Thanks
Dude I got a 2011 328i M-sport.
To answer your question. Depends on HOW MUCH BASS you want.
If you just want a "bit more punch" than the factory system. Than I would say add a seperate mono subwoofer amp.. and replace the stock subs with some 8' earthquake subs that are pretty much GREAT fits for the e90 Bmws.
Me personally I LIKE BASS I want to feel it in my chest. So I got a SUNDOWN SA-12 in a custom ported box hooked up to a Old skool Memphis st-1000.
The rest of my system is factory as I have the Harmon Kardon Logic 7 system. I probably will upgrade the mids and highs later.
What you REALLY need to do is go on the E90 forum. and readup on the audio threads. their is a MEMBER name Technic. That makes CUSTOM wiring harness for BMWs so that you do NOT have to cut any wires to add an external amp. YES I bought my harness from him.
Hi Everyone -
A couple questions:
Thanks
Hey Guys -
I contacted Technic and will be getting the harness from him. I also ordered the Earthquake 2 ohm woofers to replace the factory ones under each seat. I tried getting advice from the amps forum with no success on which amp to get.
Earthquake has a discontinued MOSFET amp which seems to pair well with these two. 150 Watt RMS per channel (2-channel) at the 2 ohms each. THD is 0.5 at 2 ohm.
There is a great deal online for $69. MSRP is over $280.
What do you think? Should I get it? Any other recommendations?
Hey Guys -
earthquake's lower end stuff is pretty crap.
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
12
277
Defiantly. LOL 😂 It has never happened to me👀:poop:
6
427
Maybe voltage loss? I always set my LFP to 80 and on steeper slope with no noticeable SPL loss. Playing a sine wave is a lot easier on your...
8
489
nexusdoan
nexusdoan
austin, tx
nexusdoan
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
