Subwoofer install without power cables..?
  • 3
I have a VW Golf 7 GTE (which hasnt the dynaaudio option..)
So i want to upgrade the sound without open anything / upsetting my car dealer
I was thinking of making kindof a "boombox" in the trunk, were there is a subwoofer with an amp and battery. but the battery wouldnt be connected to any alt cuz there wouldnt be any power cables from the front, it would just be charged every night (like the car) with a battery charger. how i would get a signal to the subamp is still a debate. most likly it would be a dual jack (one to the OEM stereo, one to the subamp)
So my question(s) are:
car battery inside the cabin bad?
would the battery die after 5mins? (would be a DDM45 500rms amp with two 15s)
the battery would be aftermarket so guide me on how powerfull battery i need (5hours max play time deacently loud)
thoughts? haha
Hope to see some replys //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
This really isn't a good idea. You will need to tap into the factory head unit for the source anyway. The only part you would avoid by doing it that way is running a power cable from the battery in the engine bay to the amp. So for the hour or 2 to do that, you would rather charge a battery every night? Might as well just do it right.
yes you can use batteries in the cabin, trunk etc. just make sure you
use AGM batteries. they dont leak acid because they are sealed
and the acid is absorbed into glass mats. as for getting a signal u will
need a LOC in which you will have to tap into one of the speakers.
so u will have to modify the car somewhat. As for how many batteries
you will need to get 5 hours of play time... well im not a battery amp
hour guy, im sure someone else here could get you a better answer, but
im sure it will be alot. Ar least 5 group 31's AGMs to start. how long it will
play wll depend on how many amps ur amp will pull from the batteries
and how hard you push the subs.
you do know you can put in a proper system and take it out when your
lease is done right? its not like your car has those seals on it that
let manufacturers know its been tampered with right? I would just do it
the right way and just remove it when the lease is done. hope this helps
good luck
Pull the head unit out, and at the harness use a test light to check 12v, ground, and Accessory. If all three are good, you have probably...
7
That blue wire with the "remote control" sticker on it: It's NOT a remote control wire. Its a remote... control wire. Its a switch that...
11
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
11
Storage is actually pretty big ( but not big enough for an enclosure that's mounted on the door because it closes in an angle believe it or not...
15
Bazzheadnorway
Norway, Oslo
EnvoyDenalii
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
