subwoofer mounting position
The L section of the port is 7" which, with the other dimensions, brings me to 32hz
Should I place my subwoofer at position 1, 2, or 3?
how much power will the sub be seeing? #2 looks to have the most uneven loading for the rear wave. On low/med power levels that won't be an issue, on high powered burps you could start tearing cones/surrounds...
I'll be powering a RE se-x 12 with 600rms.
Here are the box specs:
Width: 28
Height: 13.5
Depth: 15.5
Thickness: .75
Port width: 2
Port height: 12
Vb: 2.24 ft^3
Fb: 32hz
Port Length: 12.75
Port Length2: 7
Port Area: 24
At what point would issues arise? I'd like to be able to use this box for a higher grade sub in the future. Not opposed to building another, but if the mounting position is a factor I'd rather cut it where it would be most beneficial now.
What are the variables that would dictate mounting location?
At very high power levels the cone might not like the uneven loading of the back wave if part of the sub hits port wall and part hits back wall of the box. I've seen this issue on a few cars burping 5-6kw clamped per sub...
I’ve installed a lot of brand new subs before. Like we’d build boxes and install the new sub into the box, and then install the box and tune the...
23
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
685
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
bombsaway
bombsaway
Yup
mlstrass
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
