SUBWOOFER WIRING DIAGRAMS
I have a few questions about wiring subwoofers because end up looking at these diagrams wondering if I wired it a certain different way what would the end load be and I can’t seem to find examples of what I come up with that will answer my questions. So I thought I would ask some questions here and hopefully learn some things. I attached a diagram and I was wondering if I had 2 subwoofers wired this way what the end load would be? Mono channel and with each subwoofer wired within itself and not tied into the other subwoofer.
Usually the subwoofer instructions have various scenarios for loads. What I did when I had the same question as you, was to do various google searches with my questions and looked at the diagrams. Have you tried this website? Subwoofer Wiring Diagrams for Two 4 Ohm Dual Voice Coil Speakers (the12volt.com)
Yes and I can’t seem to find what I’m looking for.
Not sure what you mean when you say "not tied to each other. " If you have a mono amp(one channel), then your wiring will terminate at the one channel connection. I wired 2 DVC, 4 ohm subs in parallel, and got a 1ohm load. If I had wired them in series, I would have gotten a 4 ohm load. Just make sure your amplifier can handle your final load.
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
994
No. Those are speaker level inputs from the subwoofer. Lower frequencies should go to the subwoofer. The other front and rear speakers carry a...
10
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
brockjames4
Phoenix, AZ
huberoy123
    Jun 1, 2024
    May 31, 2024
