Subwoofer Wiring Problems!! Please Help!
acroach10
I have two Kicker Comp VR 12' 2 ohm sub woofers in a ported box that you can get on the Kicker website that has a terminal at one side for positive and negative so its already wired inside the box and then I have a Audiopipe AP-15001D 1500 watts class D. 1 ohm stable at 1500W RMS and 2 ohm at 950W RMS and 4 ohm at 600W RMS. The subs are 50-400W RMS range. I have tried to wire my subs and amp together and the music keeps cutting out everytime the radio gets turned up. I need to know what wiring will work and step by step on how to do it please! I need help!
How do you parallel series? And the ground wire is fine I've tightened it up because that's what I thought it was at first and it wasnt. and how do i fix the remote wire?
The ground wire could be the problem I dont know yet. I sanded away the paint where the ground is my the amp. And my subs are 2 ohm at the terminal. I have them wired negative to positive on each sub then the two positives together and the two negatvies together.
i guess that works too lol
yeah im sure because it sounds great on the amp before this one and that was only a couple weeks ago. Right when I put a new amp to the speakers its having problems. I dont know where the remote wire could be bad because i tightened the wire and everything is plugged in correctly. And ive went into the box and looked at each one and they are fine. I checked the ground on my battery and its fine, i checked the ground for the amp and its tight as hell and i couldnt even tighten it anymore and there isnt paint around the screw hole because i sanded it away. I dont know what else to do...
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
914
No. Those are speaker level inputs from the subwoofer. Lower frequencies should go to the subwoofer. The other front and rear speakers carry a...
10
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
11
Follow the wiring diagram provided https://euphoriacaraudio.com/product/ewx6neo/#wiring
acroach10
acroach10
Richmond, IN
acroach10
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
