Subwoofers are shutting off even at low base and volume output, please help.
That's all you can do if you have DVCs. If you have singles it should be at 2 ohm already. It's a very ****** amp and honestly those subs are not much better. You got hosed like thousands others do everyday by false advertising.
I just got 2 1400W pioneer subs and a 2500W amp installed in my car. The subs are 4ohms and they wired it to make it 1ohm to get maximum power output. Well, 15 minutes down the road, at the level they tuned the system at(base and subwoofer levels(-6)) it shut off when i changed the song. i stop take the key out restart the system and it works again. The amp was pretty hot. The next day the same thing happened but a lot sooner this time maybe 4 minutes into my drive. I got out and the amp was still running(light was still on). Took the key out put it back in and it worked fine. The amp this time wasn't that hot. What do you think it could be? Maybe they shoulda made it 2 ohms instead of 1 because i know the more ohm the less stress it is on the system. PLEASE HELP thanks a lot
From the bit you said. Possibly the amplifier isnt 1 ohm stable. Putting that low of an ohm on an amplifier that isnt ment to go that low puts it into protect mode. Try to put the ohms to 4. Cause you cant put two DVC 4 Ohm speakers to a final impedance of 2 Ohms.
Lighten up man, it's all in good fun. Having more to go on than I want a sub that is less than 6" deep heps the forum narrow the focus. Why...
12
Adire Brahmas were incredible subs. One of the first subs that could really compete with the JL w7s. Super flat BL curve gave the subs a really...
Placed a pair in a an enclosure according to enclosure specs below on a Crescendo Skyway 3k and they seem to be doing very nice and really...
Cool down, bro. and have a happy thanksgiving. I was merely inquiring in response to someone else's post that cautioned about clicking on the...
12
ufxcrunner
ufxcrunner
jacksonville, fl
ufxcrunner
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
